1 - 3 of 3 Posts
I clean the surfaces and installed new aluminum gasket, tightened the Sh!t and it still drips oil!!! Should I use some kind of sealer or is this a sign of some other issue?:frown2:
Did your aluminum washer fall off the offset of the screen. Mine did that once and got bent. Would not seal had to get another one
Will check it, but I don't think so, it is a new washer and the screen seemed to thread on easy and tightened.
1 - 3 of 3 Posts
