1 - 6 of 6 Posts
Hey all. Been dialing in controls / positions on my ss, and have a question about the shift lever.
There is quite a bit of play on the lever - up / down, side to side, and it seems like the majority of it is on the lever itself, not the linkage. Pulled it apart last night, and found that there is a hard rubber or plastic bushing that "carries" the lever. Doesn't seem that there is any adjustment, just that it's pretty beat - to be expected @30k on the clock. Is the bushing a common replacement part? I don't have a parts manual...
Ultimately I'll probably go with the super-adjustable cycle cat rear sets, but want to get the stick set-up "baselined", hoping to eliminate difficulty in finding neutral, etc.
Cheers,
Tom
Bushing and Seal Part Nuimbers
I looked it up.
Looks like the bushing is part #77499.3421
Seal is part #93783.1524, I bought this at a bearing store as it appears to be a pretty run of the mill dual lip seal.
Phil.
Thanks Phil, not quite sure what seal you are referring to.
Went to my dealer, and they printed me out this:
Auto part Drawing Line Diagram Sketch
#3 looks like the bushing in question, and they gave me PN 037069525 as the replacement. Also checked out a new lever when there, and it has a brass bushing pressed in.
So, is the PN they gave me correct, and I'll have to press in the new bushing?
Oops misunderstood
I thought you were talking about where the shifter goes into the engine.
My mistake.
I have aftermarket rear sets so don't know about removing the bushing but usually heating up the lever should allow you to knock it free.
Discussion Starter · #6 ·
Awesome, thanks. Kinda torn between replacing the whole arm @$60 (with brass bushing), or ordering a new bushing (plastic?) to press into my arm. Seems like brass would be better (better longevity, better tolerances?), and I'd be done tomorrow. Going to take my arm / bolt in tomorrow to compare feel with new...
1 - 6 of 6 Posts
