916 starting issues and the like (grinding!!, misfires, and stalls, oh my)
Hello all!! I have my suspicions but would like to hear your thoughts on my issues.
Background : First year (94/95) Ducati 916, pretty much stock with the exception of windshield and taillights. I am running LED rear lights + integrated signals to help reduce power load on elec system. Recently I went to all electrical connectors, cleaned them and then added dielectric grease. I replaced the heavy electrical mains (battery[-] to ground ; battery[+] to solenoid ; solenoid to starter) with some very heavy wire; 4 gauge fine stranded with large copper ends and soldered and sealed connections.
Issue 1 : When I hit the start button, sometimes the engine pops then the starter motor just spins, some times the engine turns over a few times and then screeches/grinds, sometimes it just grinds all the time.... very loud and horrible sounding. it usually takes multiple attempts to get it started, and is very embarrassing and probably bad. This is the most pressing issue!!
Issue 2 : When the engine has warmed up, sometimes the engine seems to miss a cylinder-ignition/pre-detonate and the engine sounds like it hickups or sneezes. very dangerous on a slow turn
Issue 3 : When I got the bike the radiator fan fuse was blown. I just realized that recently and when I replaced it, it cause the bike to die intermittently in town after it was warmed up. battery is good (and on battery tender each night), rectifier seems to be working but I will test that tomorrow and report back whether or not 14v when running.
I assume they aren't related but I figured I would throw them all out there to help diagnose it! like I said, I have my suspicions but dont want to "taint" the responses by mentioning them.
THANKS IN ADVANCE!!!!!!!!!!!!!!!!!!!!!
