1 - 3 of 3 Posts
Yes, everything i have is in various states of disrepair
My 916 with 16k on it has begun to get hard to shift down into 1st and 2nd when hot. Have new slave and have cleaned lubed the transfer pin going to the clutch. Any comments?
You might want to post this in the Superbike section. As for your problem you should check the shift actuator.
Thanks Bruce - yes I put this in the wrong section.....
1 - 3 of 3 Posts
