1 - 8 of 8 Posts
Is it possible that the filter being squeezed on the pump distorts the plastic housing just enough to either foul the turbine, or create a gap somewhere that stops it from priming?
What if you stick a hose clamp on where the filter would sit, and slowly tighten it.
the filter fits on the rubber sleeve below the bottom of the pump.
Doesn’t make any sense.
Madness. If I had the setup and pumps, I would not be able to sleep until I figured it out.
1 - 8 of 8 Posts
