I finished putting in the je h/c pistons with valve job w/guides, nichols flywheel, dyna coils w/wires and ignition tech sparker4 module. I still got the cv carbs soon to be replaced with 41's after I get some more cash but for now all I can say is WOW what a difference the power is strong all the way to the rev. limiter ( adjustable via ignition module) the flywheel is incredible not only in the amount of pickup through the rpm's but the engine braking is I would say perfect just the right amount the effect on the handling is amazing it feel like turning a bicycle into a turn and feels more stable through the turns but the acceleration off is amazing I still can't believe the way it blows through the rpm's I believe at some points I almost could not keep up with the shifts from steering and hanging on for life the road I was on is a 2-4 gear the road is very windy power wheelies off the corners was cool to I had no idea the 900ss could perform like this I still have to do some more tuning on the ignition timing it pings alittle that was the reason for sending the $200 on the ignition module so I could adjust it via laptop pc I can't wait to see what the 41's do
