1 - 10 of 10 Posts
I am in the process of doing hc pistons. I purchased some heavyduty cylinder stud but I need to remove the stock ones they are not broken do I need to heat them before removing any good ideas
From my personal experiences, if you're not reusing them, just use a pair of pliers to take them out... Heat may be necessary if the thread-locking material won't budge. Give them a try, but if you can't get that ever-so-satisfing crack when the thread-lock breaks loose, and/or they're not moving at all, give some heat and try again.
I just did mine and removed them by double stacking the nuts. They came right out. Wouldn't you want to heat the cases and not the studs?
Discussion Starter · #9 ·
I just got done removing the o.e. studs with a little heat. Yes the heat is to soften the loctite and I applied it to the stud to soften it. The case is to fragile to be heating in my opinion. Heating the aluminum can soften it and gual the case treads on the way out from a small piece of loctite that is still in it crystal form and not soft enough the stud can take the heat better
Heating the studs will transfer enough heat to the cases.
1 - 10 of 10 Posts
