Background - I bought a '99 900SSie with 17,082 miles that sat in a storage unit for the past 6 years. I changed the oil, timing belts, and spark plugs. I also replaced the lines for the fuel pump in the tank and cleaned out the filter and filled it back up with 93 with injector cleaner. The previous owner deleted the charcoal canister or whatever the vent line from the gas tank goes to, so I used a T to put that line (which was capped) into the drain line, and I removed the barbs on the engine for the vacuum lines and replaced them with bolts with crush washers and sealant.
The problem - As the bike warms up, it take longer and longer for it to idle down between 4k and 5k RPM. Once the bike gets hot enough, the RPMs will just hang there and I have to drag them back down with the clutch. Also, when the bike is warmed up all the way, if I'm cruising at 4k RPM and try to accelerate hard, the clutch will just slip, even though it is most definitely not worn out. Above 5k and below 4k the RPMs will drop normally, its just in that range.
Any idea what this could be or how I should troubleshoot? I searched and found this thread, but its about a carb'd bike. Do you think I have a lean condition in that range or is it something else? Thanks.
