1 - 9 of 9 Posts
Hi guys as some of you will know I've bought a job running garage queen here in Hong Kong the bikes now running...yes! When I turn ignition switch on just red oil px light on and goes off after start up. There's plenty of fuel so don't expect low fuel warning but I kind of think I should have batt charge light before and also side stand warning light. Any ideas and I excuse my ignorance cheers!
Excel Addict
2001 900SSie
Nice "job" mate
You have not stated what year your SS is but .........
My 2001 has minimal dash lights.
At key on I see red oil pressure light as the engine is not running, so no pressure.
After starting it goes out as there is pressure.
Low fuel light - amber.
Even if fuel is low, it takes a minute or so for the fuel level sensor to heat up and activate the amber light.
There is no charge light on mine.
No side stand light - it simply won't start if the stand is down. This is pin 16 of the A8 ECU wanting to be grounded/connected to battery negative to allow the engine to crank.
Neutral, indicators and high beam light will show whatever the current status is.
1999/2000 models did not have a stand switch and hence no input to the ECU or a dash light.
Don't get up me about this, but I think some or maybe all carb models had a switch to illuminate a stand down dash light.
Discussion Starter #9
Thanks for info I'll investigate soon waiting on parts at the moment and it's 35c here at the moment! Thanks again
1 - 9 of 9 Posts
