If you are talking about the 3 spoke Brembo cast aluminum wheels, then probably so. I know in my case, as I've said on my thread about this, the wheel width at the hub is identical between my 2002 5.5" wheel and the used Monster 4.5" wheel. The only issue was the bearing recess, since the Monster took a 6005 bearing and the SS took a 6303. I had the wheel machined to accept the 6303 bearing.do the 900ss/sp rims that are 5.5 swap over onto a 600ss rim?? both bikes are 95 years. im not sure on this one.....
