ROFL.Hey guys! I am replacing the seal in my clutch slave cylinder and im not sure which way round the seal goes!! I dint take any notice when i ripped the old one off![]()
Generally, the flat side goes to the side AWAY from the fluid you're trying to seal in. As in, the 'U' shape will be facing in towards the slave cylinder.
I'm assuming you're talking about the seal that sits in the slave, right next to the piston, and has the actuator shaft running through it? If it is, the factory manual shows it (well, it looks like it) flat side towards the clutch (away from the slave) -as I said above.
