1 - 3 of 3 Posts
Hey All
I need a new clutch for my 900ss motor. Basically I imported a 900 motor from the states and quarintine dimwits left my motor sitting in the weather for over a month while they screwed me over. So the clutch and basket and completley fingered.
What you u suggest
Cheers
I went with Nichols basket and Barnett clutch pack. Some have had troubles with their Barnett clutch but I have about 10,000 klms on mine so far without troubles and is just starting to clatter a bit. Only other thing is if you go with a steel basket, get steel clutch plates not alloy. You might find a good used basket on eBay as people change to slippers.
I also fitted a VeeTwo clutch hub (mine was a bit wobbly) from West Aus, a pressure plate (Speedymoto I think) and a Yoyodyne slave.
A lot of those are my personal preferences and from info on the forum but you'd be unlucky to go wrong with what others suggest too.
1 - 3 of 3 Posts
