1 - 6 of 6 Posts
browsing this site has me a bit confused about Galfer rotors.
http://www.pashnit.com/product/galfer/brake_rotors_pads.html
it seems to indicate that the 91-98 and 99+ 900ss would use the same rotor; the DF883
but the 03+ ss1000 calls for the DF660
both of the rotors are 320mm diameter, but the minor differences seem to indicate the df660 with a 10.5mm offset and 5.0m thick rotor vs df883 with 10mm offset and 4.5mm rotor
I thought that they all the FI SS's had the same Showa adjustable forks, brakes, wheels. I am assuming that that is incorrect since the require different replacement rotors. Or are they effectively the same due to the larger offset, but thicker rotor effectively negating any difference.
I am working on a 900ss/cr custom that has 900Sie showa forks and calipers, and 5 spoke marchesinis (though not sure if they were from a 900ss or 1000ss?) I just assumed all of this stuff was basically interchangeable, but perhaps not?
Anyone to provide clarification?
To my knowledge no SS came with Marchesinis.
Excel Addict
2001 900SSie
I checked a few parts lists I have for the rotor part number 49240241A
Same number/code for 2000 900SSie, 2004 800SSie, 2005 1000SS.
I also typed Ducati and that number into Google. The link below shows all models it is used on, which is many.
This was confirmed on other sites, but you should check for yourself.
My 2001 900SSe front has Brembo on it. BTW Brembo bought Marchesini in 2000
Ducati Brembo Front Rotors 748 Style: 748-998, SS, ST, Monster, MTS SUPERBIKE 748 49240241A MONSTER 400 400S 600 620 620S 750 750S 800 800S 900 900S 1000 1000S MULTISTRADA MTS620 SPORTTOURING ST2 ST4 ST3 SUPERSPORT 750S 750SS 900S 900SS 620S 800S 800
Sure my 01 SS had marish stickers on the 5 spoke rims but wd40 took care of the decals
Excel Addict
2001 900SSie
Thanks for the reminder, so did my 2001.
1 - 6 of 6 Posts
