1 - 14 of 14 Posts
FE Seat Mod:
Anyone know of someone that's modified a FE seat and added a "hatch" opening to access the storage space? Any pics/examples would be great.
Mufflers:
What brand/model are these mufflers? Anyone know this bike and could provide some side shots?
Thanks
John
Looks like you're just around the corner from me. I'm up here in the Rose Hill area. Shoot me a PM if you want to come check it out. I've only used fiberglass a few times but can shoot you some tips if you're new to it.
Awesome!!
That's awesome that we're neighbors. Sent you a PM.
John
Hey Floundering, nice work with the solo tail hatch! I'm getting ready to mount up a carbon solo tail on my 97 sp. I cried a little when I drilled slider holes in the side panels :) I'm not sure if I want to hack up the carbon more, but your mod is the best storage solution I've seen so far.
Posted this earlier today, I thought. I have a Sharkskinz solo tail w/ Sargent seat. I cut out the area behind the butt pad for access to the storage area. Attached the cut-out piece to the pad to position it, and added a small bracket. Bungee from the sub-frame to the bracket holds it in place. I use a "bungee net" in the storage area to prevent escapes. Works good, invisible, cheap and easy, not secure (but who knows its there?) TT
Discussion Starter #9
Pics...PLEASE!!! :)
I warned that I am challenged - where is this "managed attachments" you speak of? I looked, but obviously not in the right place(s). Thanks for the help! TT
Discussion Starter #13
down below the message section in "Additional Options"
1 - 14 of 14 Posts
