Thanks man, I'll definately check the connectors. By the way, where is the regulator located? Is it under the left side cover or is it outside?Ducman851 said:Try checking the connections at the yellow wires that come from the left side cover. There is a pair of psuedo bullet connectors that can get corroded and cause havoc. Short of that you may have a bad regulator.
ThanksRainman said:Welcome XR glad to see you here!
Oh great! Ask me a question I know the answer for but for the life of me old age has chosen to not reveal its locale.xr50 said:Thanks man, I'll definately check the connectors. By the way, where is the regulator located? Is it under the left side cover or is it outside?
Thanks!
ThanksJules3 said:OH NO, not the start of an oil thread. Glad things worked out for you charging wise. Buy three quarts of oil. You should use about 2 2/3 to 2 3/4 qts. Just keep it BELOW the top fill mark. Personally I like Mobile 1 15w-50, but you'll get as many recommendations as there are stars in the skyIt's your preference on the "Dino vs. Synthetic" issue. As long as you change on a regular basis with a quality oil, your good.
