My 1999 900 ss has a problem that has gotten gradually worse until now it is not reliable at all. It started by suddenly quitting while riding, then starting right back up. At first I just thought it was bad gasoline or something. It then quit on the interstate, wouldn't start, finally started but ran very poorly. I made it off the interstate and waited for about 20 min when it started right up and ran fine for the next 200 miles. It has gotten to the point now that it starts, runs a couple miles then quits. If I wait 15 or 20 min it will start again, runs fine for a short distance then quits. When it quits it just dies, no spitting, sputttering, nothing - just stops.
I had a ducati performance ecu so thought that might be the problem, so I swapped it out with the stock ecu - no change.
Help!! Thanks for any thoughts you might have.
Bruce
Bruce
