I've got quick shifters on my 999 S and 749 R track bike. I find them to be really convenient. Once I started to use them, I had to have them on all my bikes. Fortunately, if you have an Ignitech ignition, the install on a 900 SS carby is really easy.
I started with a Shifting Control quick shifter. I bought mine from Liam at Fast Bike Gear. I believe that you can buy them directly from Ignitech, as well. Personally, I prefer to buy from Liam as he's great to work with and has dome much to support the 900 SS community.
Mechanically, the most difficult part of the install was cutting and tapping the aluminum shift rod.
As far as the electrics, I crimped Ignitech pins to 20 ga wire, and connected these to the Switch 1 pins (8 and 14) on the Ignitech unit. My Ignitech is located under the seat, so between the Ignitech unit and the quick shifter, I spliced in an AMP 2 wire connector. The connector sits under the battery box, and the rest of the wiring was added to the loom going back to the Ignitech. I use Tesa tape for the loom - nice and clean.
Programming the Ignitech was easy, as well. In the software, click on Clutch Master under Multifunction Input 1 (or 2 if that's what you're using). Then program the Clutch Master time to 70 ms, and the Clutch Master Pause to 100 ms.
During my initial testing the shifter has worked great. After I have some more time with it, I'm going to experiment with 60 and 50 ms. Overall, this has been a great mod.
