this is the finished product of the last 5 months. i took my '95 900 ss/sp down to the frame and rebuilt it from scratch. had the frame powder coated and took on the project of making my own carbon fiber fairings. i took the original fairings and used them as a mold to lay the carbon sheets. painted and clear coated.
ducshop here in atlanta did the motor work: 966 overbore, st2 cams, porting with 1mm oversize intake valve, dual plug, slipper clutch, then blue printed the engine.
sil moto headers. BST wheels front and rear, brake tech ceramic/carbon front rotors matched with brembo dual piston calipers. Ohlins rear shock and a showa fork from a 748 with Ohlins internals .
42 mm flat slides of course
corbin seat to match the carbon fiber motif.
guard dog keyless ignition
european style left control so i can turn off the headlight to start the bike with the speed cell battery
lots of little add on pieces and billet
put it on the bathroon scale and it weighs in at approx 340 pounds with oil and a half a tank of gas!
runs so sweet!
runs so sweet!
