I have a little problem with the clutch on my 860. Or maybe it's something else, but here it is: I start the bike in neutral and get her warmed up. As soon as I put it in gear it shuts down just as if I've popped the clutch at idle.
After a search over on bevelheaven, I found a post that said to fix that issue I should, prior to starting, pull in the clutch lever and kick it over a few times to free the plates. Well, I've kicked like a mad man numerous times and the problem is still there.
Any ideas?
Any ideas?
