1 - 6 of 6 Posts
Hammer Down
2020 Multistrada 1260 S Touring
Where did you pick up the rear stand, did you get the reservable one?
My dealer had one on their hands. It is reversable in that it has 2 pins that came with it. According to the dealer it was for the 1098 and the 848 SF but I found that to be incorrect. The pin on the left side of the bike must be the same but the pin on the right side is a much larger diameter on the 1098 than the 848 so I took it to a buddy with a lathe and we turned it down to fit. I don't remember exactly how much we shaved down...I was thinking 300 thousandths but that would be too much I think...certainly more than 30 thousandths.
http://www.pit-bull.com/fitting_chart_pins.pdf
According to Pitbull I need the Standard Pin (which number is that?) and the #2 Adapter for the Streetfighter. Has anyone validated that this works with the 848SF?
Thanks!
I bought a #2 w/ adapter (kit packaged together). There is a #2 pin, but it is too thin so you need #2 w/ adapter. If you already have pin #2, then you can just purchase the adapter by itself.
I have it and it works.
-Ray
Discussion Starter · #6 ·
-Ray
I have a #8 and #5 Pin... Looks like I will be getting the Standard Pin w/ Adapter!
Thanks!
1 - 6 of 6 Posts
