1 - 6 of 6 Posts
OK, I know anything is possible with the right amount of money. Im not wealthy at all.
With that being said is it fairly cheap to adapt a set of 848 wheels to a 748? and if so does anyone know if its been done yet?
Thanks,
Ken
Mayor of Simpleton
Rear is a straight swap. Front is not--uses a larger axle I believe.
Find "Moto" and ask him. I believe he has posted before on what you exactly need to do this. I don't believe it is much.
I swapped mine over but I used the whole 848 front suspension and brakes. The rear is a direct swap, as already been said, but the front is a mess to get to work especially if you want to keep using the factory speedometer.
Front 848 wheel uses a 5 hole rotor with different bore and offset.
No speedo drive provisions.
Spacing is slightly different.
Axle diameter is the same.
-M
Ok, I take that back, maybe not so simple. But Moto knew ;)
1 - 6 of 6 Posts
