Its an interesting idea, but it wouldn't be very simple. The spacing between the two intake manifolds is different in the desmoquttro. So not only would you have to modify throttle body linkage, but the manifolds themselves to fit on the older motor.
Its probably doable, but I'd say not worth it in the long run. The best way to go is throw on the 748R throttle bodies and injectors, which have showers and are a direct fit.
