1 - 2 of 2 Posts
Hey guys,
I am finishing up a termi install and everything went smoothly right up to the point of resetting the TPS. My single-ECU VDST (dongle for a 5AM ECU) wont recognize the DP ECU - keeps searching endlessly.
I know the stock ECU for an 848 EVO Corse is a 5AM (says right on the ECU), so I was thinking the DP ECU would also be a 5AM. Is that not the case? If the DP ECU is different, would I be able to swap the stock ECU back in, reset the TPS and then swap the DP ECU again? Would that accomplish the purpose or are the TPS settings stored on the ECU itself?
Please help!
Discussion Starter #2
I figured it out guys! It was a COM driver issue, now the VDST works. The DP ECU is indeed a 5AM in case anyone is curious.
1 - 2 of 2 Posts
