1 - 3 of 3 Posts
Anyone had this problem? Brakeligt works fine when just ignition on, but when engine is on it just flickers when i press the brake?
Battery? Relay? I have an intergrated taillight
Thanks for any help
99' 996
Sounds like a ground issue, bad/broken wire or connector, that manifests from the vibration of the bike. With the key on, engine off start grabbing, tapping, and wiggling wires and connectors. Also check voltages along the harness with it running and without.
1 - 3 of 3 Posts
