My 2013 821 started running rough with the o2 sensors plugged in. When I unplug them the bike runs great but I have the dash light. I have the Starace intake, exhaust valve flapper removed, rapidbike evo(with custom map) , the ELDOR coil swap as well as a few other things. I read that the o2 sensors on these bikes are known to go bad. Would I be better off just buying an o2 sensor emulator module, pulling the o2 sensors and not look back? It seems like it would be cheaper than buying numerous o2 sensors. Would the o2 eliminator work fine with the rapidbike module? I have the RB autotune turned off to run the custom map.
