So, I've tried and failed for the 4th time to successfully retire from racing. After taking my M796 to the track a few times over the past few years, as well as riding it on the street, I've come up with a plan to have it as a dual purpose machine -- race it at the local club level 5x/year, but still have it as a street bike. I've gotten it to the point where it takes me a couple of hours to make the swap, with tire changing taking the most time. A plan to score a second set of wheels is temporarily on hold, but I hope to do that eventually.
1015962
The stock dash is replaced with a Motodemic bracket, which allows me to unplug and remove the headlights and front turn signals. A simple dirt track numberplate is mounted in place with some angle brackets and some old fork clamps.
Tires are swapped for Michelin Hypersport rubber (no warmers required).
Oil-retaining bellypan sourced from the UK.
M1100 forks, with stiffer springs and K-tech compression adjusters (I might get their rebound kit as well)
Wilbers triple adjust rear shock.
(I had done the suspension mods to improve the shocking stock suspension when I still intended to keep it on the road).
S2R rearsets (no ground clearance issues, and a cheap alternative to decent (non Chinese) rearsets)
Sidestand removal dongle from eBay (works perfect)
Lever guard on uprated radial master. When I bought the bike with 16,000km the front rotors were warped so I swapped them out for EBC rotors.
I have a modified collector that exits into a single 2" outlet (under the tail), with a Hindle titanium exhaust mounted. I need to map it properly, but it runs OK as is.
Remove the licence plate, tape up the taillight (integrated so I don't need to fuss with rear signals) some safety wiring, and we're track ready.
The bike comes with a shift light and lap timer, so that helps!
Back when I started racing on an EX500 20+ years ago, I had Pirelli K591s, no tire warmers, and raced in every class they'd let me. While I was mostly a moving chicane, I got lots of track time. I'm certainly not super fast, but I did have fun. At the height of my involvement 10 years later, I was hauling 2 bikes, a generator, a bicycle, tire warmers, canopy, tools, spare wheels, etc etc every weekend. Not sure I had any more fun...? Gonna live by the kiss principle for now.
Twins class currently is a bit under-subscribed, but I want to do my part and fill out the grid and have fun.
Wow! Looks like unlimited runoff room there, but is that an Armco barrier in the third pic? Are you racing on an old airfield?
I finally gave up racing when I realized I was nervous before the start, and relieved to have survived at the end! Still enjoy track days, though.
