1 - 8 of 8 Posts
I hit 7500 miles on my last ride of the year back towards the end of September 2019 before I put her up for the winter. This weekend I am taking her in to get the valves checked. I have to say I am a little nervous about the soft valve guides. I am taking her in to the DucShop, so I know she will get well cared for. I asked Mark what he thought and he basically said it was hit or miss for these engines. Next year I will be going through the same thing on the Paul Smart. Fingers crossed!
Did the same service plus replaced the belts. Everything checked out fine. I wouldn’t sweat it, I’m sure it will be fine.
Well I picked up my bike over the weekend. Everything checked out fine. Had the valves adjusted, barely out of spec, adjusted throttle, a little too much play and had the belts replaced while they were doing the work. Very happy with the price as well. A little under $500.
That’s a hell of a deal for all that work! Where did you have it done??
Discussion Starter · #6 ·
Yes, that was what I thought. I usually go to another Ducati mechanic that is near me but it was hard to get my bike over there because of their work hours. They also wanted $900+ just to do the valves. I got the work done at The Ducshop in Atlanta. They are open on Saturday, which makes it easy to take over there on Saturday morning and then pick up the following weekend.
https://ducshop.com
Did you check your engine #? You might be ok. My 2K7 GT was.
Discussion Starter · #8 ·
No i didn't bother checking the numbers. From posts I had read from the past, it seemed even some of the engines that were not within the specified range still had problems. I figured it is what it is and would just deal with whatever happened. I've still got another year before I have my PS done, about the same time next year.
1 - 8 of 8 Posts
