1 - 2 of 2 Posts
I was hoping for some input, I'm pretty sure they are but wanted to double-check. The vertical cylinder is the coil on the left which is what the tach reads off of with the gray wire and double-red 12v wire, and the horizontal cylinder is on the right with the brown and green wire and single red. Are those all correct? The 12v red wires are off the terminal on the "back" of the coil and the grounds are directly below the plugwires. Sorry if I missed a well-known post about this, I looked and couldn't find a single decent diagram or how-to.
Discussion Starter · #2 ·
Update, they seem to be, bike starts and runs well! I gapped the plugs to .035, so ~9mm; I have straight-through slipons, emission deletes, and a foam airfilter.
1 - 2 of 2 Posts
