Before changing anything I'd dump the fuel thats in the tank now - but keep it -put fresh fuel in, run it to clear out the excessive amount of cleaner in the tank, then put a 1/4 of the fuel you dumped out and run it. If that helps, next time you need fuel only use a little of the dumped fuel with a full tank. If you still have running problems it may be something else --- but doubt it......!Larry, i put the whole container in...! it still is not starting. but only with starting fluid, & then dies.
just got new injectors, fuel filter, air filter... guess it may need a fuel pump?
