As some/most prolly know, the 749R is the odd-ball when it comes to rear suspension. Stock, it has a shorter stroke (56mm vs. 71mm), much stiffer spring and damping, and a flat-rate linkage vs. progressive rate.
So, in my quest to gather as much info as possible, I've spoken to several of the well-known supension gurus and found out some pretty interesting info.
First off, There are 3 different Ohlins shocks that will fit the 749R. The DU301 "triple-adjustable" common to all 749/999 bikes, and two specific 749R shocks that are listed as OEM by Ohlins according to Dan Kyle (forgot P/N's). One of these "OEM" shock is listed as 71mm stroke, and the other listed as 56mm stroke. The standard spring rates for both are much stiffer than that of the DU301 and the valving to suit. All the shocks are 305mm in length.
Next point, info from another well-respected source revealed one particular fast racer running the standard (progressive) link with one of the longer stroke shocks. Apparently, the flat-rate link and short stroke combo, designed to combat rear-end squat, works well on smooth tracks as in Europe, but not so well here on our bumpy tracks here in the Colonies. Makes sense to me, and I may go this route for ease of setup, as I already have some good experience with setting up that combo.
So, for those with experience setting up 749R's in particular, if you wouldn't mind pleease post up some comments on your setup. I, for one, would greatly appreciate it to help me get my bike sorted for the track so I can enjoy the ride and not spend the whole day messing with suspension.
Specifically, for those lightweights (I'm 145lbs), how do you use the recommended 10-12+ kg spring (for flat rate link) and get good sag numbers? My DU301 has a 7.13kg spring and my sag numbers show that is a little light, but not wayyy off. Bear in mind, I have not yet moved the axle beyond the standard swingarm length, and I understand that will create more leverage on the spring, but that big of a jump in spring rate?
Next question is with the forks... I'm going with .90kg springs; how well will the stock valving handle that change, and what oil to use with the R/T forks (weight range? The Showas on my 749Bip handled the change reasonably well after I changed the oil weight and made a very minor change to the stock valving.
Thanks in advance, and Special thanks to Dan Kyle, NCRick (Cogent Dynamics) and Ducshop for their time and information provided.
