1 - 2 of 2 Posts
After riding my bike last night and not noticing any problems, this morning I start it and notice the low-beam light and brake light are not working. All of the other electronics such as the dash, high-beam, tail light, front/rear turn signals, and horn work fine. I pulled all the fuses and none are blown. Anyone else have this problem before?
The low-beam lamp and rear led combo (integrated turn signals, brake and tail led) was installed about 2 years ago. I know I could buy new lamps to rule out a faulty bulb, but I'm thinking the chances of both my low-beam and led brake light going out at the same time is unlikely.
Any suggestions before I take it to the dealer?
Discussion Starter #2
problem solved! low beam headlamp was burned out and the pin for the rear brake master cylinder is missing causing the brake lever to drop and the brake lamp always remain on.
1 - 2 of 2 Posts
