Hi,
I have read a couple of the how to threads on this subject and I am wondering if when you open up the canister and install the 2" straight thru baffles, if there would be any benefit at all whether sound wise or equalization of the exhaust to connecting the 2 baffles with another piece of pipe making it into an H pipe like they use on cars?
There has also been talk of the raspiness that comes with making this modification, would it not sound better if you simply removed the Cat from the canister and replaced it with another piece of pipe, this way not changing the internal workings of the exhaust, simply removing the cats ( also the other one in the Bottom pipe) .
Lastly there has been mention that in order for it to sound good and get rid of the raspiness that I talk about, there should be a size difference from the diameter of the internal baffles to the exit pipe. Should the internal baffle br larger than the exiting pipe and then what if that H pipe is added?
Thanks for any input, I want to make this mod to get rid of the heat associated with the Cats while at the same time making the bike hopefully sound better, I had carbon Leo Vinces on my Monster which sounded incredible and this stock exhaust just isn't cutting it!
I fo have a power commander and as such not worried about the outcome as icanhave bike dynoed and adjusted.
