Are all these numbers from a custom dyno tune? Meaning each cylinder was tuned.04 749S with 54mm full exhaust and PCIII.............105RWHP
I have a 04 with a full 54mm exhaust thats putting down 100 rwhp & 56 ft lb. tq. It's about the same power a 916SPS is laying down!
Thank you johnnie. I was struggling pretty hard with the 100HP. Your response was kinder than mine would have been. I would have responded with a, "No." But you beat me to the response.An SPS usually lays117-123 rwhp
to be correct
I once did a 749 05 cam dialled in that laid 100hp SAE, so it certainly can in the Dyno I use with the 916SPS at 117.
Got the graph as I save all runs, I can overlay them for you.
Not even related the two, 749 will look awfully weak.
Not stock: 2004 749R, Big Bore 848 Kit, Nemesis ECU, 57mm Termi, 130rwhp at BMS in Denver, Co. Just had it out at the track in SLC. Ser fun!
Not stock: 2004 749R, Big Bore 848 Kit, Nemesis ECU, 57mm Termi, 130rwhp at BMS in Denver, Co. Just had it out at the track in SLC. Super fun!
Pretty sure the highlighted portion is the reason. There's another person on the forum with a full-build AMA FX version putting down 140.130 whoooa, thats not even possible is it??
