1 - 9 of 9 Posts
:)So I dropped my 749 last night and it put a crack in the clutch reservoir. I have seen the reservoirs relocated to the triple clamps for the stock master cylinders. Does anyone know if there is a kit for this or do I just buy a Brembo reservoir and drill into the triple clamp. I figure if I'm doing for the clutch I'll want to do the same for the brake.
Also anyone have a left mirror wing?:)
This is one way....
I mounted the Reservoir Bracket at the upper top-triple clamp pinch bolt. It just took a 1/2" longer bolt.
For the master cylinder, you will also need to get the elbow nipple fitting for the brake- fluid inlet , as well as a standard bleeder valve.
I used Rizoma Parts:
CT027 Rizoma Side Outflow Fluid Reservoir, Wide wt Window
CT450 Rizoma Fluid Reservoir Bracket
I did this to allow the LSL raised clip-ons. With the lift, the OEM integral reservoirs fouled the fairing.
for my ST 999S
hahaha!:D
Copy THAT!
1 - 9 of 9 Posts
