1 - 10 of 10 Posts
Any help would be appreciated, I have done the searches and read several pages but found nothing specifically matching my query.
I am upgrading my 998 brakes to the 4 pad calipers. I am considering also adding the Brembo RCS masters for both brake and clutch. Will the factory 749/999 front brake lines work? Or do I need to do something yoyodyneti/custom?
Thanks,
t_bare
Mayor of Simpleton
You need different lines because the outlets on the RCS masters come out the bottom. Yoyodyne has just what you need. About $120.
The 749 come out the bottom in this diagram. The length was what I was concerned about, both from the master to caliper and again over the fender.
Thanks,
t_bare
I used the 749/999 lines with no problems with my rcs master.
Sent from my Motorcycle iPad app
Perfect time to add dual front lines, one to each caliper, after going to all the troubleand expense with the 4 pad calipers and MC's.
Discussion Starter #7
+1 on new double lines.
Its much easier to bleed aswell as for looks.
Done,
Motowheels- Master Cylinders Ordered
Yoyodyne- Custom Lines Ordered
Cha-ching.
I hope My clutch line is long enough...
t_bare
Mayor of Simpleton
Call them back and order some 30cc horizontal tab reservoirs and tygon tubing.
Discussion Starter #9
Mayor of Simpleton
Less expensive, looks better, and allows you to install raised clip-ons without hitting the fairing.
1 - 10 of 10 Posts
