As some know I picked up a 749 out of a barn last month without keys, well I was able to get dash/ECU programmed and new keys to include the red one made, got everything installed last night. I have not tried starting bike yet, but it does power up and crank over, however starter relay sticks, but kill switch stops cranking. Next headlights do not work, tail light and brake lights work, fuses are good, both bulbs check good with a multi meter and relay inside headlight bucket clicks when key is turned on, highbeam indicator on dash stays on regardless of position on handle bar switch, passing switch does not work nor does front running light. No turn signals work either, i've checked all connections a few times, no corrosion bent pins etc. .. what am I missing I hear a relay clicking in battery box, believe it's the fuel pump, as that does work...
