1 - 2 of 2 Posts
I am trying to install 04 999 triples in an 06 749 frame. the problem i am having is the stem doesnt seem to be long enough. the 749 frame does not have the eccentric neck. Does anyone have any information that would help me do this? The 749 neck and the eccentric tube from the 999 measure the same. How far down do the races go in the 749 neck? any help is greatly appreciated!!!:think::think:
the base 749 frame has a different ''neck'' as compared to the 749s,r and 999 frame.you will likely need much fabrication to adapt.look into replacing your frame of custom triples if you want to change your rake
1 - 2 of 2 Posts
