The water pump cover on the left side of the engine. There is a 4mm bolt with a copper washer that looks different from the rest... that is the coolant drain plug. Be sure to remove the radiator cap or the coolant will barely trickle out.Tried the search function here and Hall of wisdom. No luck.
Soooo, I anyone please direct me in the right direction.
Where do I drain the coolant from? Where's the coolant drain plug?![]()
Look for another bolt by the mount for the nose faring; also the triangular air deflectors (technical termAs far air filter goes. I tried removing the air runners. Started on right side.
got all 3 allen bolts fine but won't budge.![]()
1.5mm allen set screw on the lever at the push rod pivot... make sure it's loose, then 6mm wrench to adjust the push rodI read Shazaam's post regarding adjusting the master but does not show pics for the 999. Someone replied and said he was able to do it. I would PM him but it looks like he's been inactive for a while. Can anyone show me where to adjust that?
Any help appreciated and pics of to locate would be awesome.
Thanks in advance folks.![]()
Sorry, no pics at the moment
