1 - 6 of 6 Posts
Hi all
I’ve been floating around this site reading through pages and pages trying to work out how to go about tuning my 2000 748R.
I have all the gear and software working but am still trying to find a working .xdf for my bike.
And this is where things get interesting.
Looking into the ECU this is the model I have
IAW 16M.A0
16M904-BIP947
DUCATI 916 BIposto EU.
This is then being coupled with a DP965024AAA chip.
So firstly is this the ECU that all 748R’s run or has this one been switched in at some point and I need to look into differences.
And secondly does anyone have a working xdf that will be suited for the ecu and chipset above (yes I have the gear and have ripped the .bin file off the chip already)
Cheers
Jono
all 16m are the same, regardless of the sticker. i would have thought by 2000 they'd have dropped 916 of the label though. maybe been replaced.
the fuel for the xdf looks correct for a 748r dp file i have - might not be the same as yours, ive not see the 024 file - but the spark is off.
Excel Addict
2001 900SSie
At least it is a start for fuelling.
Just a messenger trying to help.
Never have been an "expert" and never will be.
@Punch - Yeah I have that one but some of the stuff looks pretty funky. Seems to work fine on a stock 748 .bin file but not the 748R one.
Which chip were you looking at with it?
Local shop owner has a stash of different chips and says I can rip the .bin files off so when I get round to it I should have a bunch of different base maps I can start from.
Just getting into this as I have a similar skill set professionally, my coding is less than up to scratch but I have enough mates to help me out if needed.
Any info I find out I’m always more than willing to share.
Excel Addict
2001 900SSie
I don't know what chip it was.
The bin file was for an ST2 and the XDF at first looked incorrect.
Then I found this info, third post down about changing the header offset and voila, all was good.
When looking at 996 files I had to change the offset back to see then fuel maps correctly.
This may help you.
Ducati 748 916 996 Bin and XDF File - Can you sort table? - TunerPro User Forum
Reactions: Aff-man
1 - 6 of 6 Posts
