Hi,
My 748 makes some big bangs quite often, not at every rpm but often, and when it does at low RPM it actually halts the engine. I have run it now with the tank of to adjust TPS and sync front and rear throttle bodies, and I then found out that it is the front cylender only that makes the bang, and that it shoots flames out of the front throttle body when it does. What can cause this? I have had the engine taken totally apart and restored (mostly by me) and the valves adjusted by a mechanic, and this problem has started after that. Since it halts the engine at low RPM, I guess it ignites before the piston is at top position and pushes it back, but what should I look for to diagnose this problem, where do I start? My guesses are the following (but they are only guesses):
Any help on where to start and what to do to diagnose this is appriciated
Thank you
Søren
- Intake valve not closing quickly enough
- Intake valve not closing completly
- Premature egnition (but why? nobody has messed with the ECU)
- Air/Fuel mixture wrong (to lean?)
Thank you
Søren
