1 - 3 of 3 Posts
The speedometer cable on my '99 748 was tie wrapped to the brake caliper by the previous owner. I'm guessing that this put it in a bind because the cable was broken about 5mm from the end of the square drive. Is the cable suppossed to just hang loose or is it suppossed to be secured some other way?
grand poobah
Mine have always been loose. I looked at the assembly manual and there appears to be no fixation. Hope that helps. Brad.
It does hang loose but if you have the showa forks one of the white fender hangers has a special flat nub on it that stops it from rotating.
1 - 3 of 3 Posts
