Hello, everyone. Got a little issue today when I was replacing the gas tank on my 98 748. The tank I was replacing with, had a gas tank mount bent for some reason (no idea why anyone want to do it, may be previous owner tried to fit it to some other Ducati models). So i tried to bend it back to it's original position and pulled a metal plate that was welded into the tank. Most of it is still welded to the tank but there is a crack on the bottom of that metal plate.
Wondering what would be the best fix in this situation?
I tried to look for some info, there is JB Weld, POR-15, Permatex gas tank sealer, epoxy, KBS, Red-Cote, welding...
Is any of this stuff actually work? I'm trying to avoid welding, may be anyone tried alternative solutions?
