What quick disconnect fittings did you buy? The ones from Colder?
I have a 2002 748s as well but the previous owner installed quick disconnect. I have never seen a Ducati fuel pump base with a banjo bolt fuel line.+1 my 2002 748S has the stupid banjo bolt nipples and I have had to make do with them for the same reason you are now encountering.
Gotham. Their site says they are 1/4" NPT. Would tapping the banjo bolt thread to 1/4" NPT work?What quick disconnect fittings did you buy? The ones from Colder?
Thank you! Explains why I have never seen a flange with banjo bolt fitting. I wonder why Ducati did that? Extra parts laying around they needed to use?+1
The banjo bolt versions are from the 748E model NOT a 748 base, R or "S" model.
could possibly be from a ST model iirc.
I thought that I was getting a QD flange when I bought it via ebay.Ebay is your friend if you have a bike with banjo fittings simply buy the QD flange and be done with it.
