Photobucket or any other image hosting service.
Photobucket or any other image hosting service.Well Hell. That didn't work.
Anybody know how to post images in-line?
ape
I used smugmug. I must have done something wrong. I'll look into it.Photobucket or any other image hosting service.
I was browsing through Sears the other day when an idea hit me. I just happen to be in the wrenches aisle and the idea popped into my head to use a 15mm boxed end wrench as my head bolt removal/installer tool. There's a twist to this though. You know what the special Ducati tool looks like right? Well how can one imitate this? Easy! Use a torch to bend the ends of the 15mm boxed end wrench 90 degrees. You could either weld a socket onto one end so you can use a 1/2" drive or simply place an allen head socket into it so you still have a 1/2" drive. Simple! Funny how things pop into your head like thisWhen I tried to remove the head bolts with the special tool I bought for that purpose, it turned out that I had the 14mm version instead of the 15mm version.
I tried using a 15mm spanner, but it didn't work too well. You can get it on there, but after you turn it, it gets stuck.
Not a bad idea. So you're saying you'd wind up with a 15 mm wrench that's shaped like a Z? That would address part of the problem, but you'd still have the problem of fitting the end around the bolt. There's very little room between the edge of the bolt and the head casing. :-/I was browsing through Sears the other day when an idea hit me. I just happen to be in the wrenches aisle and the idea popped into my head to use a 15mm boxed end wrench as my head bolt removal/installer tool. There's a twist to this though. You know what the special Ducati tool looks like right? Well how can one imitate this? Easy! Use a torch to bend the ends of the 15mm boxed end wrench 90 degrees. You could either weld a socket onto one end so you can use a 1/2" drive or simply place an allen head socket into it so you still have a 1/2" drive. Simple! Funny how things pop into your head like this![]()
No it would end up looking like a C, just like the Ducati special tool looks like. The problem of fitting the end around the bolt is a simple matter of a dremel and a grinding wheel to grind down some of the material on the end so the wrench will fit. I'm currently having to do this on the wrench I boughtNot a bad idea. So you're saying you'd wind up with a 15 mm wrench that's shaped like a Z? That would address part of the problem, but you'd still have the problem of fitting the end around the bolt. There's very little room between the edge of the bolt and the head casing. :-/
ape
Here is the oil passage I'm talking about.http://4.bp.blogspot.com/-MEQe9OPWVyM/T714ys0MIjI/AAAAAAAACug/cq_8K4X-W6w/s1600/IMG_0004.JPG
Please read over my 4v notebook again, especially the part about the oil passage in the vert cyl base and a fix!!!
Plus, are you planning to check the rockers for flaking, valve adj? He'll you've got the head off and it's so much easier on the bench!! Again, read through my blog. I lost a lot of pics and info when google did away with blogs.... And unfortunately, I'm on to the easier Testa engines. And you'd be better off getting Cometic gaskets. And... You should add another book to the mix, LT Snyders (rumor is he's back on duty but try Whitehorse Press or CA Cycle works!!
You could also go crazy and degree the cams ( read my PowerPoint ) does make a difference. But I hear the off set keys are had to find- but I think the adj pulleys on some of the Desmoquattro bikes will work!
Good luck, and like I say in the blog. "Don't be afraid to dive in!!"
Let me know if you need more help
[email protected]
Tricklidz, that's just the picture. Do you have a link to the actual blog?Here is the oil passage I'm talking about.
First one: Maybe the fuel pump connector?The first connector appears in the first three pics. The second connector is in the last two.
Can anyone offer a clue?
Thanks Luke, I'll check the back of the starter solenoid tomorrow morning. And the fuel pump. I'll let you know how it turns out.First one: Maybe the fuel pump connector?
Second one looks like the connector that plugs into the back of the starter solenoid.
You got it in one Luke.First one: Maybe the fuel pump connector?
The sad thing is, it just illustrates that I have clearly been spending too much time taking my bike apart and not enough time riding it!You got it in one Luke.
davy
