Last weekend I rode my 2000 748 up the mountain to Paluma
(195 turns in about 30 km)
About 5k from the top, it kept dying in slow corners, but came good with revs.
It also popped more than normal on the overun.
On the way down it ran just fine and did so for the 60k ride back home.
Seems to run normally now.
What do you all think? altitude related? (Paluma is almost 1000metres above sea level)
relay problem? spark plug?
It was a fairly warm day, about 30 degrees C
Also I went to check the plugs with the factory toolbag spanner, but it doesn't fit. The spanner is 16mm hex. I see from the NGK site, the plugs have an 18mm hex, is this right?
davy-j
davy-j
