1 - 6 of 6 Posts
Recently bought a 748 with 9100 miles on it had a slight issue with the fuel lines inside the tank replaced that and it ran fine was out riding the bikes and it died got it back home Checked the fuel lines one had come off from not tightening it enough when I put it back together I crank it over it ran for a second shut it off tried to start it again because it was flooded it vapor locked and now when I turn the key on it will do nothing
Pretty sure its not possible to vapor lock a loop injection system.
Key ON, what do you see and hear? Lights, dash lights, any clicks, a whirring sound for a few seconds, nada...? Voltage at battery? Battery & ground wires all tight and connections clean?
Need more info to assist.
1 - 6 of 6 Posts
