1 - 2 of 2 Posts
My gauge cluster all of a sudden stopped working after a ride. Also the blinkers don't work either anyone have any suggestions on where I should start or what should I do to begin fixing the problem or finding out what the issue is?
This is my first Ducati so I'm not familiar with them yet. Someone please help I would much apreciate it.
I had a similiar problem with my 2002 998 besides dash gauges and turn signal, I lost the horn and tail lights. Checking the fuse block I found four fuses with not power on either side, all of them were fed by a relay. I think is was call an ignition relay, although the bike ran fine. The relay was located above the battery on my bike and when I when to check it it was rusted from water damge and someone had duct taped the cover back on it. I replaced the relay and have had no further problems
1 - 2 of 2 Posts
