Installing a new AB upper and lower on a 1997 Ducati 748. Track fairings are a bit tricky so I've been taking my time working methodically. After installing a DB Holders fairing stay and shaving a bit off the tip of one air runner, I have the upper fitted.
My issue is the with the lower fairing. The bottom hits the lowest point of the exhaust pipe that runs under the bike and therefore I can't make the two edges mate with the upper without bending it into an awkward shape. Not to mention having a hot pipe pressed directly into the fiberglass
. It's a stock pipe, so it really shouldn't be an issue.
Attaching a bunch of pictures here. Wondering if anyone who's installed these in the past can give me any pointers. I could drill out a relief for the pipe and build something up to seal the belly pan, but I really only want to do this as a last resort...
Here's the root cause. This is looking forward, courtesy of a probe.
I have the fairing staged as close to the final position as I can get it. The wood is supporting exactly where the pipe contacting the fairing. Everything seems level, kickstand and rear pipes are clear.
In this position, the lower fairing doesn't come far enough up to properly mate with the upper. These photos are taken with the fairing balanced as evenly as I could get it on both sides. I can fasten the left side dzus but it makes the gap on the right side worse.
The front-to-back alignment with the upper looks fine.
