1 - 20 of 22 Posts
My new swing-arm arrived after long awaited anticipation and thought I would share some pictures with the group.
It increases the length by 20mm.
Awesome we can still get these!!
Mayor of Simpleton
It's easier to get the longer swingarms than the longer chain rubs and chainguards that go on them!
Reactions: TomTom
Chain guards and rubs already picked up.
Duc, I've got one of the same swingarms.
Where did you get the longer chainguard and chain sliders?
Reactions: juan1 and paulmm600
Discussion Starter · #10 ·
mpaschetto
Longer chain guard picked up from Motowheels and chain sliders are stock OEM from Gotham Cycles x 2.
Chain guard bolts right in to existing holes, but the sliders required splicing to achieve the longer length. Two top and two bottom were required.
pics coming soon. Replacing bearings at the moment before bolting back in place.
...but the sliders required splicing to achieve the longer length.
pics coming soon.
Cool. I'd like to see how you accomplished the splices... :)
Discussion Starter · #16 ·
Clean the arm real good to remove any grease or dust
Cut two pieces of stock chain guard @ different locations to get the added length
splice with a piece of safety wire
Apply some Black Strong Waterproof Adhesive Double Sided Foam Tape ( locations near welds will need 2 layers to make level ) (Do Not File Welds Down )
From Film on tape and apply, screw into place
Pics of the top chain rub and Carbon guards installed coming soon
Discussion Starter · #18 ·
I like that idea and will be implementing once these are worn out and in need of replacement.
The 3-d printing is only getting more and more affordable.
Guess I should ask for orders and buy in bulk?
If you can get me the dimensions, center-center for mounting holes, etc. I'll model it for you and then give you the model in several neutral formats that you could use for printing.
1 - 20 of 22 Posts
