Hi,
The final parts needed to complete my '74GT motor build are 4 #0755.92.250 Rocker shaft bushings. Does anyone know of a source for them?
Thanks,
As far as I know, they are not available. Did you manage to replace the shafts? A possible solution would be to get some new bushes turned up, which are a tight press fit in the rockers, and the correct clearance on the shafts, and use desmo shafts, which have an oilway cut into them.
